wallowing like annoverweight porker and major oversteer
  • wallowing like annoverweight porker and major oversteer
    About a month ago on a trip down to Glasgow in torrential rain as usual my usually steady as a rock baby decided to nearly put me into the middle of a roundabout due to oversteer which I thought may well have been due to greasy wet road. However after I had collected myself together and carried on. I noticed that I had very little resistance wen cornering and she was wallowing about like and old sofa! Had her checked out and a track rod end was almost done. So I replaced both. Tracking all done but still.much the same? I'm thinking anti roll bar bushes? Any ideas anyone before I start replacing all front suspension parts and steering??
    Geeman
    Yes, I would check both ARBs, maybe a broken link?
      That would explain it wallowing about... What about the oversteer?
      Geeman
        What tyres have u got on it-front and rear?
          Cooper at/3's 17"s
          Geeman
            Cooper at/3's 17"s
            Nice tyres. Well it shouldn't be them then. More checks on steering system needed.
              Do you have the hard soft setting on the dampers?
              www.overfab.uk
                Yeah.the hard setting is not much different any more. Used to be a noticeable difference but not anymore
                Geeman
                  possible damper failure.
                  www.overfab.uk
