Iv a feeling my dual mass flywheel is on the way out guys,rattling a bit the last while and a bit juddery.Its a 2lt-e gen 2.thing is iv got a hiace sitting in the yard with a 2l and g52 box...solid flywheel.will the hiace flywheel and clutch/pressure plate work without any issues?
hiace flywheel
yes/no.Originally posted by Paul ssrg View PostIv a feeling my dual mass flywheel is on the way out guys,rattling a bit the last while and a bit juddery.Its a 2lt-e gen 2.thing is iv got a hiace sitting in the yard with a 2l and g52 box...solid flywheel.will the hiace flywheel and clutch/pressure plate work without any issues?
by mem it will fit but they are a smaller diameter clutch plate than what you need and won't last long. my surf came fitted with one and it got promptly thrown out.
what you need is a 2.8 (3l) clutch out of a hiace. you can also use hilux flywheel but need the hiace pressure plate and use the old 2lte bearing.
i'm not to sure. it was a fair while ago when i did mine.Originally posted by Paul ssrg View PostSo can I use the 3l clutch with the 2l flywheel?
i don't know if a 3l pressure plate will bolt up.
the other issue is the 2l flywheel surface may only be machined for the smaller 2l clutch.
might be a case of get the pressure plate etc and see if it bolts up and lines up ok. if it doesn't 3l flywheels are not that hard to get.
