mista brown jamaica
  • mista brown jamaica
    my hilux surf 1998 turbo diesel taking a long time to strart
    can anyone advise me please and thanks
    I think we need more info...
    can you video it?
    does it smoke when it starts?
    does it run ok once started?
    how long is a long time?
    when was it last serviced/fuel filter changed?
    how old are the glow plugs?
      Try starting it before you light a spliff.
        wrong way round
          its had new glow plugs 2 good heavy duty batteries my mechanic an you help c
          says it could be the glow relay if you tun on the ignition and wait
          for 90 seconds at least it will start 1st time if not i keep the key turned
          until its starts its not right
            Is the glowplug fuse OK?
              mista brown
              can you video it?
              elay
              the glow plugs a new few weeks 2 good batteries i was told it could be
              the glow relay i even had a dionistic and he said could be the fuel pump
              can you help plesae & thanks
