I have a 1995 KZN130 with 120,000 miles on the clock. Firstly ATF is clean and more on the high side rather than the low. Occasionally,but more frequent of late,pulling away in Drive has felt as though the vehicle is under resistance similar to having the handbrake on --- change down -- it is fine and then go back into drive -- is fine. Also put it into 4WD in high and manoeuvre or turn corners at slow speed and resistance is felt, especially through front wheels----is this a transfer box problem?
