Hi guys, Just after a bit of advice, been running 50/50 veggie through the winter. No problems apart from being a little rough at idle. As the weather has picked up I have tried 90/10 veggie mix, again truck has been running fine however I recently noticed a leak on my drive. Managed to trace this to the injector pump and was worried I potentially had a big bill. Checked the large nut around the white plastic plug and it was a quarter turn loose. I have tightened it up and all seems well with no further leaks.
Do you think the extra mix of veggie has increased the pressure on the seals?
Would it be worth changing the injector pump seals as I know Rough traxs do a seal kit?
Anyone know someone local to Leeds who could do this for me as I have a feeling stripping the injector pump could be a nightmare?
Appreciate any advice,
Thanks Nick
Thanks Nick
