Hi all
A quick question about multimode 4WD on a gen 3 Surf.
Noticed recently that I get a noise / small judder when turning on wet roads with 4WD engaged.
When I had the rear prop off and running with 4WD centre diff lock didn't have a problem with it front wheel drive only on full lock.
Is the centre diff starting to play up in any way, or is it normal and I just not noticed it much before.
Tend to use 4WD in wet to stop back end stepping out under power on corners.
Thanks
Thanks
