All
Not been on for a while as the truck has just kept on trucking. Until last night, just as I pulled into the driveway, alot of steam escaping from underneath the bonnet. Engine temp immediately shot up. I had noticed earlier that day that it seemed to be down on power on accelerating. No prior problems.
Anyway, some troubleshooting today. I ran it up to temperature a couple of times, and it didn't overheat. I'm getting vented hot air through the vents. Oil seems fine. However, I filled it with coolant/water mix this morning and that has GONE. No leaks. Just refilled it with straight water ( I'm out of coolant ) and running it up to temperature again.
Ran it with the rad cap off to do a gentle bleeding. Hit the acc pedal and got a coolant fountain out of the radiator. Not sure if that signifies anything. While I was under there, I also noticed I have an oil leak.
