Got the dreaded timing code 14 , just can't rid of it..... replaced injector pump tested the valve tested crank angle and sensors ,started when light came on and that horrible diesel knock now we over the knock engine runs ok but there is no power due to ecu putting it into safe mode (limp)
Is this something I could fix by resetting the ECU ?? Or is the ECU up the wall ???
Any help would be great
Paul
KZN-185 3.0lt import
Paul
