kzn-185 rear axle seal
  • kzn-185 rear axle seal
    hi folks
    the rear axle seal on one side gone and got the relevant kit from roughtrax...
    local garage done it but leaking again ....ordered another kit but hes quite stumped as to why its still leaking....can only fully strip and try again..
    any ideas?
    cheers
    paul
    I have the same problem. I believe that there are two seals - outer which is near the brake and inner which is deeper into the axle.
    I have just bought the inner seals and will have a go at changing them. Bushwacker did an excellent photo guide on here a little while ago - a search should find it.
    Cheers,
    Mark
