I had the pipe from the bottom of the PAS reservoir split yesterday, so emergency repairs meant the only hose i could find to fit was "gas/emission" flexi hose. Equally, the only fluid I could lay my hands on was STP bog standard PAS fluid, with no standard or spec anywhere on the bottle.
Reading afterwards, I see Toyota spec a Dexron ATF fluid.
Anyone know if the normal STP PAS fluid the same? or do i need to flush? This post on Yotatech suggests I will be OK, but I always like a second opinion, especially with US boards:
http://www.yotatech.com/f116/power-s...l#post51964270
Also will the fuel hose last, or disintegrate before too long...?
I've found a write up on the flush process, if needed, but could do without the hassle today TBH
http://www.yotatech.com/f2/3rd-gen-p...ng-post-81347/
thanks
Dom
:http://www.yotatech.com/f2/3rd-gen-p...ng-post-81347/
thanks
Dom
