Toyota Surf Gen.3 clutch noise
  • Toyota Surf Gen.3 clutch noise
    I have a generation 3 toyota surf manual when its ticking over or driving I can hear a screeching noise from the clutch when I press the pedals slightly down the noise goes away I have been told it's a thrust bearing can anyone help? Can I replace the bearing only?
    You can, but you still have to take the gearbox out,so replace the lot whilst at it.
      Thanks FricFrac I will do. Any idea labour time in hours?
        Autodata books it at 3.3 hours to remove & install
          Thanks YDevil i will oder parts from Roughtrax
