Hi to everybody, you have a good forum here!
I have a 1991 Surf that has problems with 4WD. I have extensively trawled this site and the Australian one along with Google and have found no posts that deal with my specific problem.
My transfer case was not engaging properly either on the switch or from the lever going into low. I have successfully sorted the ADD vacuum issues and the selector switch on the lever. I took the transfer case motor off and inspected and tested it. It works well and there is no sign of corrosion. The disc that the electrical contacts wipe on was not removed so I cant see how I could have changed its timing.
The selector rod in the transfer case can be pushed in and out by hand.
Having reattched the transfer motor (several times) I find it will engage 4WD but although the motor operates in both directions, it will not disengage fully which is confirmed by viewing the gears and rod behind the four bolt plate on the side of the motor.
When reinstalling the motor I have had the rod fully retracted with the motor in its fully retracted position, then fitted the large gear that has the pinion on it.
I have also tried it with the opposite setting with the rod in.
Can somebody who has direct experience with transfer case motor fitment please point me in the right direction.
My apologies for a lengthy first post.
Thanks.
I
Thanks.
I
