does anyone know how to get the engine management fault codes on a 1990 ln130 2lt, i've been told that if you have bridge two wires in the diagnostic port under the bonnet by the battery (little grey box) then numbers or lights will come up on the dash giving you a fault code, but i cant seem to find out which wires. any help would be great as im having a stressfull time figuring out why it keeps cutting out!!
cheers
baz
cheers
baz
