Are they the same for a 2.4td and 3.0td?
master cylinder
ok, why then, did an Aussie member state that the 3Ltr has a 1 1/16" bore when he had to replace it? The 2.4 has a 1" bore. Have you measured both Vince? Can't really go by the Toyota part number as I don't think the 3Ltr master has a lug for heat shield, so this alone will make it a different part number.
Nev.
Mine does have 1 1/16 cast into the top of the cylinder under the resevoir. It transpires that the master cylinder is not at fault, but a brake pipe rotted out in a really bad place to get to (on the chassis toward the rear of the fuel tank and behind the spring mount) just where all the shite accumulates. will I have to replace it right up to the master cylinder or can I joint it toward the front end of the fuel tank as it looks in really good condition there?Old enough to know better but then again.....
