Kzn130 1994 3.0 lt drove spot on parked up for a week went to start no joy Engine spins fine plenty of power lots of fule but will not fire up tried to do diagnostic check no lights flashing notice there is no engine check light at all not sure if it's CPU or pump there is lots of pressure at filter no fule at injectors when you crank engine over all help great fully received all in all not a clue regards kc60 PS there is a topic had same problem but there is no answer so you don't no how or if he got it solved???
