Hi All,
Mine has black wheelarch extensions with rubber rubbing strips on their inside edges, presumably to prevent causing marks on the bodywork. I'd like to have them matched to the body colour and sealed with the bodywork so they look more part of the bodywork than afterthought add-on.
Would the following be the way to go?...
Remove all 4 arches, remove rubber strips, and have them professionally painted using the colour code from the VIN plate.
Refit to body without rubber strips, and seal the inside edges to the bodywork with the closest colour silicone sealant I can get to the body colour.
Thanks for any replies,
Mark
Mark
