If it is the front seal leaking then after you remove the pump sprocket you may be able to do it without removing the pump. Never looked at doing this so not sure if it's possible. The seal is a 22544-64740 genuine part number and Denso 096039-0040.
Now, the hardest thing about sorting the fuel pump is getting the bottom pulley off. Easiest thing to do is remove the radiator, and get a hydraulic puller. Do not hit the pulley with a hammer as you will ruin it.
