hot & cold marks on atf dipstick
  • hot & cold marks on atf dipstick
    hi folks just changed atf fluid today would I b right in saying I check level when fluid is hot ? as there is 4 marks on dipstick iam not sure which ones r what? can some one tell me how to check the fluid properly thanks
    regards big ssrx
    Yes check levels when engine hot.
    Park up.On level ground.
    Cycle through gears.
    Check level.
    Eat.Sleep.Surf.Repeat.
      ok check when hot what mark do I go with cheers
        The fluid level needs to be within the two lower marks when cold, and within the two upper marks when hot.
          before I changed it the level was on the top mark put bk in what I took out and it is over the top mark should I check it when it is cold then top up if needed ?
            The main thing is to check the level with the engine idling, then refer to post #4.
              ok thanks for your help , is it ok to mix gen Toyota dex 111 with another dex 111 ?
                As long as its all dex 111 it's fine.
