The general servicing info specifies Hypoid gear oil for front and rear diffs. How is this different from normal gear, as the guy in the motor factors says its all the same.
So i put some semi-sythetic 75w-90 gear oil in my front diff. Is this ok, anyone?
Del
So i put some semi-sythetic 75w-90 gear oil in my front diff. Is this ok, anyone?Cheers
Del
