I have had a rumbling sound coming from the front passenger side. I replaced the wheel bearings but the sound is still there. It is most noticeable when turning left. Stripped it down again and this time notice a bit of play on the shaft and what appears to be a bronze bush. Could this be causing the rumble? I should also say I have replaced the cv joint on this side thinking that was causing the problem. I never noticed the play on the shaft inside this bush.
Thanks in advance.
Mike
Thanks in advance.
Mike
