Hi folks I'm looking at deleting the air con today as the system is charged since the condenser is US and I won't use the system as I have a sunroof
The belt going around the fan isn't needed to drive the fan in anyway is it? I see that there is 2 belts driving the fan and water pump but just wanted to check that it doesn't need both and that there isn't any sort of drive slip in between the 2 belts and its a solid drive from the rear belt if you get what I mean.
Marty
Marty
