My auto transmission gears are holding much longer before changing from 1st-2nd, then 2nd-3rd, then from 3rd it wont change into 4th gear(Top) at all. The trans has worked perfectly for nearly ten years, and with no signs of problems until now. I checked the trans oil level with engine on, needed 1 ltr top up, drove for 1 mile then gears changed down as normal. 2 days later, same thing again. Checked oil again, all ok. Not sure why gears sticking. Not sure what makes an auto gearbox change gears. Has anyone had this problem? Help!!!
