In anticipation of resurrecting the beast I have two important questions.
I am fitting an after market temperature gauge seen as the standard one has similar accuracy to that of ####ing in the wind.
What is the correct running temperature? What temperature is concerning/damaging?
I can set my gauge to alarm above a certain temp which is pretty useful.
Would it not be better to put a cheap gasket on instead of a higher quality one?
I know it sounds like a stupid question but logically speaking; if a weaker gasket is installed then its more likely to give in before the head if (god forbid) it overheated again. If it doesn't overheat again then the the gasket shouldn't let go anyway regardless if it is cheap or not.
Correct me if I am wrong?
