Hi All.
I have a problem with (I Think) the ADD system in my Surf. What Happens is this…After a recent trip (about 4 Days later) a horrible grinding noise started, it sounds Like 2 spline gears not engaging right. just rolling around at the ends (not slipping together) Action: take the end Flange off the hub (to stop the left hand drive shaft from turning) no more noise
but no more 4wd
It even makes the noise when 4wd button is pressed in driving around.
Had the Surf on a Hoist today with all 4 feet dangling (looked very sad) put the flange back on the hub started it up & put into 4wd to see if it worked & it did. Was it Because it was hanging on a hoist with no load? & when on the ground it has more load eg weight of the surf?
Any ideas would be appreciated. 1 confused surf owner & another confused mechanic
John
but no more 4wd
It even makes the noise when 4wd button is pressed in driving around.Had the Surf on a Hoist today with all 4 feet dangling (looked very sad) put the flange back on the hub started it up & put into 4wd to see if it worked & it did. Was it Because it was hanging on a hoist with no load? & when on the ground it has more load eg weight of the surf?
John
