Diff breathers for wading.
  • Diff breathers for wading.
    Hi All,
    Why can't I find a wading kit for my surf when there are hundreds for the dreaded LR brand??? I can find the breathers so extensions for wading must be necessary must be needed, yes/no? Experts.
    Tribs
    Out
    http://www.hiluxsurf.co.uk/showthrea...light=breather
      I've had a search on the forum but no avail..... is there anyone on here who still sells kits made up?
        The easy fix is to get some vacuum hose, connect into the existing breather and feed it into the engine bay.Coil it around 3 times, tie wrap to something solid (brake pipes or fuel pipe) and job done
          The easy way is wrong, and no easier, do it the same was as in the link vince gave you.
          well, that was a bad idea!
            Thanks for the input guys.
