Hi there all!
Coming to the end of jobs to do on my Surf, thank god
but just one thing is niggling at me.
Engine comes up to temp (on gauge that is, half way), top of rad is from I read is meant to be toasting hot, as are heater hoses etc, heater working nicely too now but rad bottom hose is luke warm, so is rad until top tank..
Header bottle is filling up about 25 mm when up to temp and then returning to normal on cool down.
New rad cap, stat, rubber hoses, everything flushed through plenty times and bled via a water bottle stuffed in the stat housing/filler neck.
Looked through the search database but people with same symptom were having overheating issues, i'm not. Or is this just I have a very effective cooling system
P.s viscous fan has been overhauled and if anything needs more oil.
Thanks in advance for any advice!
but just one thing is niggling at me.Engine comes up to temp (on gauge that is, half way), top of rad is from I read is meant to be toasting hot, as are heater hoses etc, heater working nicely too now but rad bottom hose is luke warm, so is rad until top tank..
