To Anyone Who Can Help, I Have A 1989 Surf 2447td Manual Transmission, It Has A Rancho Suspension Upgrade And Big Wheels And Tyres.
Last Week While Towing With It, The Car Devloped Problems Symptomatic Of A Worn Out Clutch, I.e. While Trying To Accelerate In Gear The Engine Would Rev High But Only A Small Amount Of Power Would Go To The Wheels, As If You Were Slipping The Clutch.
Assuming The Clutch Was Worn I Had A Mechanic Replace It For Me, The Old Clutch Was Almost Worn Out But Still Had A Little Life In It.
The New Clutch Did Not Solve The Problem, The Mechanic Looked At It Again And Thinking He May Have Installed A Faulty New Clutch He Replaced It With Another 1 To No Avail.
It Was Then Suggested That It May Be The Transfer Box So I Replaced This With A Second Hand 1, But The Problem Persisted.
I Was Also Told That The Vehicle May Have A Limited Slip Diff In The Rear Axle So I Disconnected The Rear Prop Shaft And Put It Into 4wd Powereing Only The Front Wheels, But Still No Luck.
The Car Seems To Go Into All Gears Fine And In And Out Of 2wd, 4h And 4l Easily.
There Does Not Appear To Be Any Oil Getting On The Clutch.
The Mechanic Says That When Looking Through The Inspection Panel He Can See The Clutch Releasing Fully.
All The Symptoms Point To A Fault In The Clutch But I Am Now Totally At A Loss And Can't Use My Beloved Car, If Anyone Can Help With Either A Solution Or The Loan Of A Gallon Of Petrol And A Match I Would Be Eternally Grateful.
Many Thanks Jez.
Many Thanks Jez.
