Fuel pump not working, rebuilt, Please help
  • Fuel pump not working, rebuilt, Please help
    Hi folks,
    I'm a new member and new to surf ownership, I have a 2.4 k reg ssr-x, with only 79,000 miles on the clock.
    Have had some probs with the fuel pump leaking so had it rebuilt, work fine for a while but now the pump does not operate when ignition is turned on, even priming the pump by hand has no effect. Also interrogated the ECU and it spat out a bunch of fault codes : 2,5,7,8,12.
    Basically I'm looking for some guidance as to where to start looking/fiddling first.
    If anyone could shed some light/experience on this for me I would greatly appreciate it.
    Thanks.
    John.
    Have you checked to see if it has a live feed going to it when ignition is switched on? If you have then can you hear the solenoid click?
    I'm also new to surfs but that's where I'd start.
