Hi folks,
I'm a new member and new to surf ownership, I have a 2.4 k reg ssr-x, with only 79,000 miles on the clock.
Have had some probs with the fuel pump leaking so had it rebuilt, work fine for a while but now the pump does not operate when ignition is turned on, even priming the by had has no effect. Also interrogated the ECU and it spat out a bunch of fault codes : 2,5,7,8,12.
Basically I'm looking for some guidance as to where to start looking/fiddling first.
If anyone could shed some light/experience on this for me I would greatly appreciate it.
Thanks.
John.
Thanks.
John.
