Evening all I recently fitted a set of replacement complete tie rods from RT .when I fitted them I had the truck jacked up all was fine but tonight is the first time I have looked underneath with the suspension under load. What I have found is the os inner track rod end is slightly fouling the main relay arm. I popped the os tie rod of and compared it the my old genuine one and I have noticed that the RT inner track rod end is a diffrent shape and larger in diameter causing it to foul has anybody come across this before?. Thanks
RT tie rods
I'm sure Barry will get it sorted for you - R'trax are very good when things go wrong.
