Diffs?
  • Diffs?
    Anyone know if 3.0ltr and 2.4ltr halfshafts are the same size and
    spline count?
    I have 3.0ltr diffs here, kindly donated by Gary R.
    I want to fit these diffs to Lex VIII, wich is currently running 2.4ltr G144
    diffs.
    Still on a mission.
    Second generation 2.4 and 3Ltr are the same.
      Cool, thanks for that Nev.
      Still on a mission.
        they are the original 2.4 diffs from lexurf v (ln130)
          http://www.hiluxsurf.co.uk/showthread.php?t=73011 ?
          Have'nt actually looked at the diffs to check, when you said you swapped the
          4.56 ratio diffs for 3.42, that was good enough for me(4.56 being 3.0ltr diffs)
          Still on a mission.
            Most 3.0 autos have 4.10 ratios (G294) - the 4.56 tends to show up on manuals. (G254)
              Hmmm. I have a 3.0L Manual and it's the G294 4.10 Open Diffs This contradicts the above two opinions.
              What am I missing? Or is it never a strict rule?
              I know it's an old thread but I'm shit scared of starting a new one. Shit scared!
                I said 'tends' to show up on manuals.
                The G254 diffs are not very common. All the 3.0 autos I've seen have the G294/5 diff.
                Whenever I've seen a G254 diff its been on a manual.
                As to what you're missing, it's a different gear ratio. If you'd like your engine to rev a few hundred rpm higher at any given speed then swap in the 254s....
                Rob.
                    Thanks Rob.
                    I wasn't having a go. But that was obvious, right?
                    Just doing some searching and researching and I saw those two comments, back to back, which made me ask.
                    That's why I asked "what am I missing?".
