I have a 96 Surf 3L - The four wheel drive llight is flashing - it doesn't make any difference whether I press the 4WD button on or off it is just constantly flashing., Normally when the dirve is engaged the lights flash for a short time only. Any suggestions?
Four Wheel Drive
It's broken.Originally posted by timmacp View PostAny suggestions?
It'll usually be one of the position switches, split vacuum lines or the 4WD Solenoid on the back of the T/Case.
Whatever you do, don't let anyone take the solenoid apart untill its the last resort, they are a nightmare to get put back together and get the timing correct.4x4toys.co.uk - Keeping you on and off the road...
