Lifting inside rear wheel when cornering?
  • Lifting inside rear wheel when cornering?
    Anyone else suffer from this?
    Fix - take off the rear anti-roll bar.
    Has worked a treat on both my 3rd Gen's with no side effects and better axle articulation off-road too.
    If you're lifting an inside rear whel on a solid axled vehicle, you've got proper isues with either your vehicle or your driving.
      Seriously, lifting a wheel?
      Never heard anything like it! How fast are you going round corners?
      3rd Gens has about 10-12" of travel stock (at least) on the rear end, it must be nearly falling over! and then you removed the ARBs?
        Well not exactly lifting - but spinning
        Yes really.
        Uphill corners and not driving like a nutter either - just the nice torquey 1KZTE.
        Same with both vehicles - same fix with both vehicles. Try it - you might like it!
          Aye, well done; I got hooked.
            I don't have any ARB's on my truck, front or back.
              ARB's?
              Tony - that's interesting. Both mine had them front & rear (SSR-G & SSR-V).
              Have you taken them off or were they never fitted?
                Took mine off to re-bush, effin pikey's nicked it. but it is better offroad.
                  I took them off for better axle flex, its wallows noticably round corners now, but I drive very relaxed these days, and truck is built to work offroad, stiff suspension is a no-no.
