Hi
Once again I turn to all you good Surf people for some advice. My Gen 2 has quite a loud rattling coming from the front when driving along, I have found there is some in and out movement on the drive shaft, not a lot but enough I assume to make this noise, is this a problem and what is it? Also I have quite a bit of play in the steering which would appear to make it wander and I'm forever correcting it to keep it in a straight line, any ideas what I should be looking at/replacing? I need to add to the rattling bit that it doesn't seem to do it when 4WD is engaged.
Any help/pointers would be hugely appreciated.
