its not lifted mate its standard the shaft comes out where it goes into hub it comes out enough to lose drive to the wheel is there suppose to be a clip on this shaft cheers
Hi, mine was the same a little while ago. The groove is quite close to the end of the drive shaft (5-10mm i think). My cv joint was shot because it had chewed up the broken snap ring. If your cv isn't noisey try to get the bits of broken ring out before re-assembly and apply new grease.
