Did some more investigation. Part number 90206-10059 is not listed for the LN,VZN or KZN130 models. It is for a lot of others. This is what makes me think you may have the wrong shoes, so it needs checking ASAP.
Those are the right parts. The fitting kit is generic, so you can expect a couple of 'extra' parts.
The videos are for the right truck too, although I've not watched them.
A wee tip; when it comes time to take the discs off the hub, lay a wheel on the ground with the outside facing the ground then lay the hub in place in the centre of the wheel. Makes removing the disc bolts a breeze. Before you re-fit the discs, make sure the mating faces are clean and flat.
