KZN185W-GAPXT 1996
hi all, newbie here.
Above vehicle misbehaves when in top, cruising, sometimes, under light load. For instance reached say 55 MPH then 'flutters' between overdrive and top every one or 2 seconds, with the rev counter reflecting this by +-800revs. throttle position kept absolutely steady, no changes in incline - even does it on the flat (not downhill tho)
Have adjusted kickdown cable, no difference (which is as expected as no-where near kickdown)
Does not do this in any other gear, or under moderate acceleration.
Auto fluid red and fresh.
Any Ideas gratefully received. PS have read the manuals thread, does the Toyota engine manual cover the gearbox too?
Tony
Tony
