I wish to change the oil & filter in the auto transmission of my 3.0 Hilux Surf SSR-X 1996. I have the Toyota Filter, but Toyota say there is no gasket. Can anyone please advise what to use to seal the mating surfaces between the sump & gearbox please?
auto transmission sump gasket
You need something like this;
http://www.island-4x4.co.uk/sump-gas...vb-p-3804.html
I did my 2.4 about 5 years ago and no problems up to press.All the best
Originally posted by Roger Garwood View PostI wish to change the oil & filter in the auto transmission of my 3.0 Hilux Surf SSR-X 1996. I have the Toyota Filter, but Toyota say there is no gasket. Can anyone please advise what to use to seal the mating surfaces between the sump & gearbox please?
They do exist (in the U.S.A. at least) although they're listed under Lexus.
The Lexus LS400 and SC400 (soarer) sump pans are exactly the same as the Surf's.
http://www.partsgeek.com/catalog/199...an_gasket.html
http://www.bestvalueautoparts.com/Sh...askets&mode=PA
http://www.transmissionpartsusa.com/...-00094140d.htmLast edited by BUSHWHACKER; 11 September 2011, 22:53.
Use something like "Permatex grey" to seal the pan back on and the filter is a mesh screen so you can wash that out with petrol or similar. Unless you are lucky the cork gaskets tend to leak after a while as due to the pans being "Glued on" in the factory they can distort during removal (which causes all sorts of cursing, swearing and gnashing of teeth). I never remove the pans unless there is a solenoid problem rather just "Drain and flush" for which you will need 10-12 litres of fluid, Something like or equivalent to Valvoline Maxlife being the "poison of choice" in this instance
!!!!! ouch!
