Cut the bottom tank off show what the ATF cooler looks like in the 3rd gen's radiator...
Doesn't look very substantial does it? Hardly big enough to cope with normal running let alone towing. It's just a stack of very thin hollow alloy plates with 1/2" Dia. inlet/outlet tubes.
Definitely going to be fitting an aftermarket cooler now, probably a stand alone with a thermo fan.
There have been a lot of 3rd gen cooler fails reported on the US sites, resulting in coolant in the transmission. Type 'Strawberry milkshake' into the search box of T4R.org for example, almost all failing at around 100k miles.
