ok 10 days ago my 3.0td 1994 td 2nd gen surf broke down, i was running it on veg, i got a mile along the road, it lost power and went slow, got a bit smokey and cut out, it would not start so got it towed home.
a week ago i changed the fuel filter, drain the veg oil from the fuel tank, rinsed tank with a few litres of petrol, added 10L of diesel, i blew down the fuel pipe to make sure there was no blockage. I took it a run and after a 2m it lost power and drove slow so i just made it home, the engine light was coming on and off. So after this suspecting pick up filter in fuel tank was blocked.
today i fitted a bike pump to the fuel line at the fuel filter housing and pumped air down it, i could then blow down it by mouth with no resistance so all was clear. I had to jump start it again and i took it a run the same way as last time and sure enough after 2m it slowed down but the engine cut out this time and i could not start it, there was not much power in the batteries even tho i had just done 2m so they soon went flat too. I disconnected the batteries and reconnected them, got my audi a4 along, jump started it, after a few attampts it finally fired up and i drove it home slowly which was half a mile.
so guys do you have any suggestions what this could be it does not seem to be related to veg oil although i thought it was at first.
