Originally posted by stormforce
View Post
Firstly, chock one or both of the front wheels. Then jack up one side of the rear axle. Release the hand-brake and put the gear selector into neutral (press the red button to move the stick). Now get under the back of the truck, and look at the top of the brake drum, you should see a rubber grommet. Remove the grommet and inside you should see (with the aid of a torch if necessary) a small knurled wheel. Using a small flat headed screw driver you can turn the wheel to adjust it (it only turns one way). Adjust it so that when spinning the wheel, you can feel a small - but obvious - drag on the wheel from the brakes. Repeat for the other side. Once done, you should find that the hand-brake only comes out a few notches, and the brake pedal will be much firmer.
