can anyone help with my problem? my 1996 3ltr turbo diesel started missing,lost power then cut out,i changed the fuel filterwhich was full of water&some gunge.engine starts but misses,after a very short run losses power,however,after pumping hand primer on filter housing,engine comes back to life for a short time then you have to repeat the process,any help would be great,thanks
fuel problem
Sounds like it's drawing air....would explain the water and dirt but so would a years old filter. Try and get hold of some clear fuel pipe and fit it on the feed to the pump. If there are air bubbles in it, then it's drawing more than fuel..........
hi,the primer loses firmness when left,what could that indicate,thanksOriginally posted by tonupteabag View Postpossibly a blocked breather on the fuel cap or a blocked pickup pipe filter in the fuel tank, could also be the primer does it stay firm once it's been pumped hard or does it lose the firmness when left (without the engine running)?HTH
Diaphragm in the primer is letting air in, if you pump until it goes hard and leave it for 30mins and it takes pumping again to harden i would assume it's naffed, my own can be left for this length of time and will take one pump to be solid again.Originally posted by kenny blair View Posthi,the primer loses firmness when left,what could that indicate,thanksI'M ALWAYS IN THE SH'T, IT'S ONLY THE DEPTH THAT VARIES!!!!!!!!
hi,i think your right about diaphragm,do you know if it can be replaced?thanksOriginally posted by tonupteabag View PostDiaphragm in the primer is letting air in, if you pump until it goes hard and leave it for 30mins and it takes pumping again to harden i would assume it's naffed, my own can be left for this length of time and will take one pump to be solid again.
without knowing what your truck actually is look at these twoOriginally posted by kenny blair View Posthi,i think your right about diaphragm,do you know if it can be replaced?thanks
http://www.roughtrax4x4.com/?doc=16&cid=611&vid=551
http://www.roughtrax4x4.com/?doc=16&cid=618&vid=1414
Roughtrax has a good name on here so i wouldn't hesitate to buy anything from them but if moneys tight you could get a S/H unit to tide you over from Tonyn or Any of the other breakers on here HTHI'M ALWAYS IN THE SH'T, IT'S ONLY THE DEPTH THAT VARIES!!!!!!!!
