CV joint gaitors
  • CV joint gaitors
    im wondering how hard it is to replace the front outer cv joint gaitor on the drivers side, my one is split and doesnt look like there is much grease left in the joint.
    and where is the best place to get a new one from?
    thanks
    milners or roughtrax put them in to google and should find the website ? not sure if stormforce will sell them separate to the CV??
    i replaced mine a few months ago bit of a pain as have to disconnect the CV from the wheel and front diff then thread it out but there are write ups on here and the aussie forum with pics! should take a couple of hours
      thanks im not looking forward to doing the job but its gotta be done. i spotted it was split when i did the track rod ends. it cant be as hard as doing them can it lol. there was a lot of swearing involved.
        swearing at the surf is what makes you a good mechanic! so too is slinging a hammer or spanner across the drive!
          oh and one more thing, should i do the inner boot too even tho it looks ok, or shall i not bother as it aint broke yet lol.
            http://www.roughtrax4x4.com/?doc=11&cid=146
            there you go link to inner and outer! its up to you if you have the money! but dont want to do it twice!
              yea ill do both, might as well as its off, there quite cheap too.
              thanks for your help. ive got a feeling more swearing will be involved when it comes round to doing them.
                I've just done mine tonight. well, since friggin 3pm! finished at 10pm! Did all 4 BJ's, all 4 CV boots and both full tie rods..
                The first one i was crappin myslef mate! got ###### drive shaft in my hand panicking! But, really, they're not that bad. I just got em both in a bucket of boiling water for 5 mins to soften them up first, they popped on ok after that, and i filled them with the supplied grease.
                While your going to the trouble of taking off the drive shaft, it'd be daft NOT to do both boots..
                www.vidamusic.co.uk
                  you can get the boots that slip over a cove so you dont have the remove the joint, cant remember what they are called but have seen them used, it took the guys seconds to fit,
                  SWIFT AND BOLD
                    If you doing outer you have to take inner off to put new one on so do both.....
                    Look at me giving advise.... hope you ain't read my exploits when i did mine....
                    "Oh look a circlip wonder where that came from"......ggrrrrrrrrr.....
                    Guess I learnt the hard way.......
                    Oh yeah don't fling spanners too hard they tend to richocet back at ya.....
                    Have fun........
                      http://www.bailcast.com/products/dur...-boot-kit-250g
                      There is a you tube video on how to fit them
                      SWIFT AND BOLD
                        £155 plus an air line is a fair few boots, or even a couple of trips to the local garage and let them get greasy for the same money....
                        www.johnthebuilder.info
                          that was just an example the link i cant find came with the cone and grease and was for about 30 quid, but sods law cant find the ###### link
                          SWIFT AND BOLD
                            http://www.youtube.com/watch?v=so9gMxzJH4k
                            Found it
                            SWIFT AND BOLD
                              Fair enough, that sound more reasonable. One of mine split a while a go. I know the joint is now probably fcuked so delaying the inevitable...
