hi really hope you can help. was having probs with my 2.4 ln130 with starting turned out to be gow plugs and the bus bar all fixed and working lovely. didnt need car for a day or two go to start it and nothing, not even the stater motor kicking in, nothing. it was all working great the day i used it. all the lights come on, fan comes on, wait for glows, turn key to start and nothing. please help!
help please, not starting
Start with the basics. If battery not flat try starting in N rather than P, and/or wiggling the gearbox shifter whilst holding the key in the start position. Dont jump to doing starter contacts straight away. Check for voltage at starter motor when start selected. If you do not have 12v ish, then look "upstream".
Let us know what you find.
