Ever wanted to know what the 2nd/3rd gen's auto transmission filter/strainer looked like?
This is what the inside of the just removed sump looks like, showing magnets.....
This is the strainer bolted in postion......
Strainer removed......
strainer housing.......
This what it looked like in a transmission that had done over 100,000 miles from new, the strainer was spotless!
So if your transmission is playing up, it's safe to say it probably isn't worth dropping the sump to 'clean' the strainer, it's either an ECU, cable adjustment or fluid problem.
