hello can a d i y mechanic change glow plugs & if so is it easy kzn 130
diesel glow plugs kzn 130
injectors have a torque setting and a small "crush" washer sits at the bottom of the injector hole, just tighten to torque its on here somewhere, I think its stickied in tech/mechanical, if not try a search for cylinder head, the manual for a later model than mine is there for download with all the info needed. H
