The front output seal (front prop) on my transfer box is leaking. Is there anything complicated or pre-loaded at the seal, or is it a simple flange off job?
Transfer box seal
I've done lots, they arn't like the diff flanges that are iffy with the pinion if you loosen then.
Just undo the big nut and the flange pulls off, just take a note of how far in the seal goes, I can't remember off hand if they go up to a stop, i have a feeling you can knock them in to far, but that might be something else, you'll see when you hook it out, but measure to be sure first.4x4toys.co.uk - Keeping you on and off the road...
