Hi chaps,
The surf is a 3rd gen intercooled turbo diesel automatic...
Shortly after buying my surf i went for 4wd but its stayed in 4wd the lights flash on the dash constantly regardless of what you do with the lever or button.
I've read all the past threads on this & the only one that helps is swapping the vac pipes round to release 4wd but the dash lights still flash!
I have done thousands of miles here & abroad with it still flashing & the pipes reversed but how can i fix it?
Cant bear going under the bonnet every time i need 4wd!!!!! Especially as winter is around the corner again..
All the best, Rob....
