3rd gen steering play
  • 3rd gen steering play
    Wondering what is more likely to be causing the play in my steering.Always seem to be moving the steering wheel to keep her straight and there's a steering clunk when going over rutted ground. There's a few degrees of play at the steering wheel.
    Inner track rod ends worn, or wear in the rack, or do I just need the alignment etc set up ?
    She doesn't pull, just wanders a wee bit. Outer T R ends, ball joints, shocks and springs, roll bar bushes and drop links and tyres replaced.
    Will have to get underneath it and track it down when I get home I suppose, just seeing if anyone had seen similar problems.
    3rd gen 3.0 SSR-V '98 R
    Worn steering rack bushes are very common ( almost inevitable I think )in 3rd gens. Roughtrax do the bush kit. So thats worth a wee lookie
    Bogus
    Сви можемо
      Forgot to mention I've checked all the rack mounting bushes, all OK...
