3rd fuel pump ?
  • 3rd fuel pump ?
    Is it mechanical or electric ?
    Cheers.
    www.scottishmudclub.com for scottish events
    Without looking Fraser I'd suggest it's electrical..
    Early 2nd gens (LN 130, LT's) were Mechanical n facelift (LN 130, LT e) were electrical yours must be ..
    (runs away n hides)
    Jess
    "Cos short cuts can cost more in the long run"
    Buncefield Burner
      3rd gen is electrical
        Mine's petrol.
          They're all mechanical if you want to get technical. Anything with an E has electronic gizmos attached though.
          Nev
            So its both.........
            Reason i ask is i run on veg and someone asked me if it was mechanical or electric pump.
            Would it be a bosch pump ??
              Nev
              Come on Nev thats enough of this technical stuff
              I'm not sure but i think its the same pump as the 2nd gen 3.0 but i will check though
                Sorry, I'll try to behave myself.
                Up to 7/'98, yes. Different part number after.
                Nev
                  It wont be a Bosch pump, but it will be a reverse engineered Japanese copy,so essentially the same, probably a Nippon Denso. Must look someday.
                  Bogus
                  Сви можемо
                    Very good copy (as all things Japanese tend to be) of a Bosch pump as Bogus says
                    Jess
                    Buncefield Burner
                      Nev
                      I didn't wanna get to technical Nev for the dear boy ...
                      Jess
                      Buncefield Burner
                        Cheers guys
